Use the following procedure to retrieve the port egress CoS queue statistics. The system displays the statistics of the forwarded packets and bytes, and the dropped packets and bytes.
- Select CoS Queue Stats.
- Select the Interface tab.
Interface Field Descriptions
The following table describes the fields from the CoS Queue Stats Interface tab.
Name |
Description |
Index |
Indicates the loopback port number from 192(1/1) to 241(1/50). |
ClearStat |
Clears the port egress statistics. |
Que<0–7>OutPackets |
Indicates the out packets by CoS queue number 0–7. |
Que<0–7>OutBytes |
Indicates the out bytes by CoS queue number 0–7. |
Que<0–7>DropPackets |
Indicates the drop packets by CoS queue number 0–7. |
Que<0–7>DropBytes |
Indicates the drop bytes by CoS queue number 0–7. |
